Technical  Clutch help please...
Hi all. Its G force.
I hope the attached is enough info.
Tim
I've just changed just the slave cylinder as our pipes are clean and our pedal was very light at the bottom. It cured the clutch issue.
Also on our gearbox we could do a rapid gear change and catch the gears if we were to quick.
Interestingly though. I've taken out the modern fully synthetic gear oil and put mineral oil in it. So the gear oil was too good as it didn't allow the synchro to work properly. The gear change now is vastly improved.
Thanks everyone for the discussions
Tim
You illustrate the point I was making. The latest oils can be too slippery for older synchromesh gearboxes. None synthetic to the Fiat spec will be more than good enough. But as Jocks asks, can you remember the oil which worked best?
Sorry - forgot to follow up on this.
So yes - the part from Ebay solved the problem... :)
Genuine Fiat Ford Clutch Master Cylinder 1544174 55187040 KA 500 panda​
