What an interesting post PB. During my time in the trade I've "sorted" many clutches and a juddering clutch is quite a common complaint. In my experience due usually to either contamination of the friction lining (often due to a failed gearbox input shaft seal and less often to a failed crankshaft seal) or a "cooked" driven (friction) plate and the high spots on the pressure plate/flywheel thus caused. Very occasionally though, after reassembly with new components and vigorous rubbing down of the flywheel face with emery cloth, there would still be a small amount of detectable judder - nothing like as bad as before. Now I'm wondering? You've given me something to think about there and something to carefully check if I ever do another clutch.
Hope you are keeping well? Poor Mrs J has been quite ill for best part of a fortnight with some nasty virus. It's frightened the pants off me that it might be Corona but we went to the Airport drive through test centre - which wasn't exactly "drive through" we spent about an hour and a half crawling and creeping, slipping the clutch a LOT (cringe), a car's length at a time, in an endless serpentine queue, and got checked. Luckily the results are negative - our Doc thinks it's a derivation of flue or similar which she's had - She's almost back to normal now, just exhausted, so I guess her immune system must be at an all time low just now. We are being very careful about contact with others.
What an absolutely horrible year this has so far proved to be. What with Mrs J having been seriously ill 3 times now (once requiring hospitalization with pneumonia) and further serious illness in our immediate family I feel as if I have been emotionally bludgeoned!
Now I'm wondering what the airport experience has done for the clutch which took a real hammering in the queue at the airport. (cooling system coped well though with the fan running almost continuously) Awfully glad I don't have one of those automated 'boxes - like our Dualogics or the VAG DSG's with their dry clutches. I think creeping is probably extremely bad for them? However it's making a change to be worrying about something mechanical, which I can probably "sort" if it goes wrong!
Take care everyone and don't let your guard down against this sodding virus!
Regards
Jock
Regards
Jock
