- Joined
- Dec 11, 2018
- Messages
- 24
- Points
- 61
Hi All,
For your entertainment.... Just replaced this 84000 mile, 13 yr old clutch after what appears to be release bearing/finger failure (see photos - as it came apart). Really quite explosive with little warning (about 3miles). Flywheel survived - driven plate was intact. Fitted new original 3 piece clutch, and a non-original release fork (I know).
Lovely smooth clutch now, with light pedal. 'Only' significant issue is it really crunches in reverse, and 1st really tight... gearbox selects all gears smoothly when engine off. Have bled slave a couple of times, and also fabricated an extension to the slave plunger, but only slight improvement. I've ordered a new slave (not arrived yet), based on info gleaned from this forum, and an unwillingness to open everyone up again and fit a 'proper' release fork. There is some rotational slop at release arm, mostly in shaft (a little on splined shaft), but that is due to new thicker clutch disc and flatter diaphragm spring as I understand? Its about 5mm at the 'cup' of the release arm. I did the selector shaft seal, but checked for proper function of all gears before putting 'box back on car. Gave the input shaft seal a miss as no play in shaft and no leaks (as the photo shows).
After a week of outside November gearbox work and chasing parts, bit deflated! Any suggestions appreciated.
