Technical  1.9JTD
Technical  1.9JTD
PandaQ
Pretoria South Africa
Hi guys I actually own a Panda 169 1.2 8v 4x4
But I want to fut the 1.9JTD engine, does the engine need a ECU or is it still a mechanical setup?.
In other words, can I fit one without having a ecu to the engine,
TIA
Regards
PandaQ
Im pretty sure it will have an ECU, but am sure someone will confirm. I would check the weights of the engine too as its possibly going to be quite a bit heavier. I think its likely to be quite involved. Panda diesel would be a 1.2 multijet which would be technically less of a stretch. Good luck!!
Events Team
Join the team
Psst! Are you free August the 1st??
Then come and join us at FIATs and Friends.
Held at the British Motor Museum, there will be loads to see and do so there's no excuse not to be there 😜
Sign up using the link above to register yourself for our stand - everyone is welcome!
