barneyfife
Problem: Fiat Multipla 2009 1,9JTD 120HP 88KW has oil leak at turbo (huge), and intermittent power loss around 3200 RPM.
Actions: Sent original turbo out for repair, and reinstalled (24 hour turn-around). Scan tool (ECM Blutooth tool and app "car scanner pro") showed MAF faulty. replaced.
Turbo Variable vannes not moving. (No vac on line) Replaced waste-gate controller. (runs like a bat outta hell) for first 8 to 10 minutes. then feels like it goes into liimp mode, but not really. No codes or faults on the computer. It actually runs lean it seems. Power at 3200 RPM drops off a cliff. Voltage below 12V drops to 10V at sart. Replaced battery. Voltage now good to Computer.
Graphed all sensors in test drive. when working, Pedal position goes to 100% and fuel pressure rises accordingly. When not working, pedal position goes to 100% aand fuel pressure stays at 4000psi. Looks like a fuel pressure regulator is not working. Removed Fuel pressure regulator (PN: Bosch 0928 400 680). Worst case scenario is computer malfunction. Regulator connects directly to engine management computer.
Notes: The way it feels I'd say that the previous owner added a tune. Thus wearing out the turbo and fuel pressure regulator quickly. I saw boost pressure of 30psi !
This little regulator is the hardest part to change, other than the alternator on the Multipla.
Parts supplier for fuel injection parts at a great price: AutoRicambi | +421 323 217 202 | [email protected]
www.auto-ricambi.eu
Status: Fuel pressure regulator and gasket on order.
www.auto-ricambi.eu
