Old 15-07-2019   #1
Sound of water sloshing around when turning
Hi All
Hope everyone is keeping well. I haven't been doing much on the car due to other things going on.
But the Panda 1.1 keeps driving albeit with EML still on.
Only thing I have done is attaching the AIR filter cover to the Carburetor like hole securely, because last time I noticed it was detached, and the Panda has been driven like that for a while. There were hint of petrol smell in the car, and mpg was really poor.
Now petrol smell in the car has gone, and MPG has improved especially for motorway driving. It managed to do 500 miles with one full tank. It was the best mpg I have seen.
And when I check the coolant, it was a bit low side. I couldn't see the level of coolant from the reservoir actually due to clouded casing. I torched into the hole and just could roughly guess the level.
I poured in some coolant into the reservoir, and the level rose to MAX.
But then I am hearing noise of water sloshing when driving and especially when cornering from the dash board. It's like the Panda is carrying a large bucket of water in front, and water is getting sloshed all over.
She still drives fine, temp gauge is just under the centre, and mpg seems normal too.
Any thoughts on this? Thanks.
Theleman is offline Reply With Quote Quote
Old 15-07-2019   #2
Re: Sound of water sloshing around when turning
You are 100% right to check the coolant as any drop in level will blow the head gasket. If the level has been low you will need to bleed the system. The Forum search will give you "How To" info.
Have you checked the heater intake below the windscreen? It has soft plastic plugs to allow trapped (rain) water to drain out but they can clog up with dirt. Open the bonnet and look behind engine, below windscreen.
Thanks Theleman, buttonsandzips thanked for this post
DaveMcT is offline Reply With Quote Quote
Old 15-07-2019   #3
buttonsandzips has donated!
It's pretty much always this! Eventually you end up with wet feet. A stuff piece of wire, like a metal coat hanger is handy for this, poke it down in the hole, release the rotting leaves and the water will flow out!
Thanks Theleman thanked for this post
buttonsandzips is offline Reply With Quote Quote
Old 15-07-2019   #4
varesecrazy has donated!
Quote Originally Posted by buttonsandzips View Post
If its a 1.1..
You can squeeze the duckbills yourself.
Odd though..as rain has been light of late.
Old 15-07-2019   #5
Quote Originally Posted by varesecrazy View Post
Hence me saying all that guff about coolant leaks. Maybe its been through a car wash.
On mine the duck bills were so hard, they fell out when I tried to clean them. They now just hang there until I can be bothered to fit new ones.
Old 15-07-2019   #6
It's good to know that it is not something serious
I recall that duck bill thing under the wind screen in the bonnet. It did leak liquids into the drive way this spring, and I was wondering about that too.
Need to get an old wire coat hanger out, and stretch into straight wire. Only problem might be is that recently all the coat hangers I have seen in the wardrobe were made of plastic.
Old 15-07-2019   #7
Quote Originally Posted by Theleman View Post
Just squeeze it..!!
Thats the whole point of its design..
Old 16-07-2019   #8
" MandaPanda "
Johnbee's Avatar
Johnbee has donated!
I keep a thin flexible bamboo cane in the boot, for pushing the rotten leaves through the duck bills every few months.
‘Mandapanda’ 1993 Panda Selecta
'Toy' 2018 500S Twinair 105
Johnbee is offline Reply With Quote Quote
Old 18-07-2019   #9
I've had a similar problem with my old 1.1L 169, after not using the heater throughout the summer, an airpocket had developed in the (my memory is a bit fuzzy) heater core (might be an upturned U-bend like in the 100HP), as soon as I purged the air from the heater core, problem seemed to stop.
Sounds kinda similar since the air would purge itself, making a sploshing sound while driving and drop my coolant level in the reservoir, causing the temp gauge to go to red.
BreakerBarDanny is offline Reply With Quote Quote
Old 28-07-2019   #10
I opened the bonnet, and located the rubber duck bill just below wind screen. It was looking bloated with some stuff in it. When I squeezed, water started pouring down from it. It was a lot of water gushing down for a half a minute at least.
When I tried to squeeze again, the rubber duck bill fell off. I looked into inside, and it was filled with black stuff gunky and horrible. I took it to the outside tap, and put it in bucket to make it loosen so it could be cleaned out.
So we drove the Panda without the duckbill, and I forgot about it until this evening. I will need to clean it put it back where it was before? Not sure how to put it back.
My Panda is showing no sign of heating up on the temp gauge in dashboard. It is always just under the centre, and if the car is standstill and engine running for a while, then temp gauge goes up to right on the centre.
Old 29-07-2019   #11
Sounds like you have it sorted.
The duckbill on mine is resting in the drain hole because I just cant get the grommet slot to sit properly. It's been fine for 10,000 miles.
Old 29-07-2019   #12
Yeah, as I said, I don't know how to put the detached duck bill back on. It is needing a through clean first after a couple of days of soak in the bucket.
And then, I was thinking of putting it back, where it was hung in the bonnet, but I was quite not sure if it will stay on there, as it looks the duck bill is so loose texture rubber. I couldn't imagine how it has resided there for last 10 years.
As you say, maybe the Panda doesn't need the duck bill to run around next 10 years. I hope so. That would save me from cleaning it.
Unless somebody comes up with advice that no without it, it will kill the Panda because blah blah ...
Old 29-07-2019   #13
Its to loosely seal the cabin air intake from enginebay fumes.
I managed to drop mine back into the hole.. from above.. inside the scuttle.
Old 29-07-2019   #14
Trader Rating: 1
portland_bill has donated!
Mine had gone inflexible, so I bought new ones. They are a loose fit in their holes. If you squeeze them, they can be pushed up into their locations and then allowed to just sit. Their purpose, as well as to try to keep engine bay fumes out of the heater, is to help the water drain away from the bulkhead insulation, to avoid dampness and deterioration.
13 years motor trade, 16 years motor industry. 17 years Driving Instructor & 10 years Fleet Trainer
Panda Alessi (2015 Skoda Fabia)
portland_bill is offline Reply With Quote Quote
Old 30-07-2019   #15
Would you say that I better wash and clean it off, and put it back to where it was before?
Is it an essential item to be there for the car's health?
(T) Water running/sloshing sound Craikeybaby 500 38 11-02-2017 21:23
(T) Liquid sloshing sound? psychofox Punto (Mk1) 9 20-01-2014 14:02
Swishing water sound/Bleed water coolent?? HELP PLEASE!!! charlieg30 Lets Talk FIAT 6 24-08-2012 14:52
(G) Sloshing sound Willsevo Punto Evo 12 28-10-2010 20:34
Strange sound when turning! HELP!! Camillo FIAT Boo Archives 8 14-07-2003 18:35
