Panda (Classic) 3 Sisleys and a 'HOLE' lot of TLC
So this weekend has been a rather busy one. After an impromtu ebay purchase, me and the old man made three 180 mile round trips to Gloucester to retrieve three Sisleys in various states of neglect.
1 red H reg with 95k on the clock and 2 blue F regs with 60 and 65k on the clock.
All have been off the road for quite some time and there are no documents to accompany them, but at £600 i thought it was a bit of a steal.
One of the blue ones has taken a nasty hit, and the sills are completely shot so the body is a no go. It still has the engine, gearbox and running gear. The other has a taken a shunt to the front left wing but with a strong amount of tlc could pass as a rough and ready green laner. With no gearbox and a pretty sad looking engine, i'll likely use the crumpled blue as a donor. Saying that all of the cars are non-runners and without having had a proper look im just speculating.
Now the red one is definately a feasible project, with 'fairly' solid sills and no major dents in the body work (despite the awful doors) she looks to be the bread winner of the lot. The inside isnt so 'wild' either.
The majority of the weekend has been spent loading, transporting and unloading, as well as cleaning out the garage for the new inhabitants so ive only managed to take a handfull of photos.
So the basic plan is to leave the red one for the time being, since she is the least desperate and doesnt look so much of an eye sore on the drive. My priority for now is to strip the blue without the gearbox and assess the body properlly to decide whether she is a keeper or not. If so ill be spending some time on the welder, scraping all of the broken bits and stripping the second blue for all of the useful parts (not keeping my hopes up though).
I'll try and keep the thread up to date with the work and have some more detailed pictures up next weekend after ive gone over the body with a screwdriver and hammer :D
Btw, does anybody have any recommendations on cavity protection? I will fill it with cavity wax when everything is welded back together but I want to make sure I get everything covered whilst I have them cut open.
I'm thinking a good covering of Red oxide/ zinc based primer. Any other suggestions?
Go on quickly!!! Needs tons of pics[emoji1360][emoji1360][emoji1360]
Great progress so far! At this rate them three Sisleys will be back on road by end of 2017. I presume that last meet at Freddy's was the final straw for you to get in to 4x4's.
Looking forward to see some sparks...
Well believe it or not the red H reg started just a battery and a squirt of petrol in the carb ran for about 5 mins then packed up when Adam came home all the electrics work
too [emoji209][emoji108] not bad for start last in 2007 !!!!!
The home made spit working well it's damm easy all welds down hand ?!!!
Cut out the rot then make a new bit grind weld then grind ! Best panel beating skill employed
Next week will be a full face transplant
From our twin blue Sisley , followed by 35 mm engine drop then a further 25 mm lift front and 50mm rear dropping U. J. 20 mm Going to get the tank sand blasted then plastic coated best opinion . Punto 1242 carb engine lined up evil panda on the way !!
Two set of sills fixed. The MIG Welding could be better but I have two more to practice on after this, and it's stronger than ever. Maybe opt for gas instead of flux core next time.
Coated with red oxide primer inside and out, to be followed up with cavity wax once it's back on its wheels.
Excited to get to business on the doors with my far superior TIG welding skills, that's if I think I can salvage them.
... followed by 35 mm engine drop then a further 25 mm lift front and 50mm rear dropping U. J. 20 mm
Just be careful with the lift. Ideally both front and rear should be raised by the same amount - if not you might open Pandora box
i.e. under/over steering, amplified body roll and squat during braking if the rear end will seat much higher.
Looking forward to see further progress.
I think he will be fine..
1. The rear always sits higher even under power - better to level it up.
2. For off-roading having the front sitting higher is always a better thing.
3. The standard gearbox flange on the near side should take a minimal lift fine - but don't go over 25mm or disaster!
4. The install of a larger (heavier) engine will probably drop it back down a bit. This WILL encourage more understeer in corners though and as Jacob states, lift-off over steer due to light weight rear end and solid axel on leaf springs!
Keep the updates coming :)
