As standard the Grande punto uses......
A H4 Halogen 55/60W bulb for Headlight and Main beam (ensure they are UV cut)
A 501 5w wedge (capless) bulb (clear) for parking/side lights
A 581 21W amber bulb with 120 degree offset pins for the indicator
Replacing the headlamp bulb....
Right First locate the tab on the rubber cap and pull it off (and don't loose it)
Next grab hold of the black multi plug and wiggle and pull to remove it (if it wont budge go to the bottom of this page)
Now the multiplug is off its time to release the bulb (at this point look into the headlight and make a mental note of how the bulb sits)
now to free the bulb
the bulb is held in place be a piece of sprung wire which is retained by a small hook at the top of the light unit,
to release press the top of the clip towards the front of the car then push it to the left (as if your stood at the front of the car)
Once released push it down and out of the way
now you can pull the bulb out......
Now for the new bulb
DO NOT TOUCH THE GLASS ONLY HANDLE BY THE METAL BASE IF YOU DO TOUCH THE GLASS CLEAN WITH METHYLATED SPIRIT OR IPA
slowly slide the new bulb home making sure the bulb sits properly in the bulb holder the 3 tabs on the metal base will only sit in one position if your having problems look through the lens and line it up visually then wiggle slightly till it drops in place
Next lift up the wire and push in and to the right so it locates under the hook
Push on the black plug ensuring the 3 terminals line up
and refit the cap.....
and test the lights the beam pattern should look like this if not chances are you put the bulb in wrong and the 3 tabs are not correctly aligned if in any Doubt get the alignment checked by a Garage or MOT station last thing you want to do is blind oncoming motorists...
Now onto a bit of trouble shooting if you cant shift the plug
I had no problem with mine however having helped another member do his bulbs the mulitplug had a very secure grip on the bulbs contacts and wouldn't budge even when applying a high amount of force.
If your's wont budge dont yank it too hard the last thing you want is to snap the retaining hook for the sprung wire...
instead try this (ensure the lights are off as there is a chance of putting a short on the lighting circuit othewise).....
undo the spring clip this enables the bulb to come out slightly (however not very far)
insert a small flat screw driver into the gap and twist the driver slightly, then rotate the bulb and plug and insert the driver again in another location and twist, do it a couple of time then pull it off
Side light Bulb
Nice and easy this one..
Remove the cap on the back of the lamp unit as in page 2
now you will see a gray/white cap at the back of the side/parking lamp bulb this just needs a slight pull (NOT on the wires on the holder itself) and it will come out
now the bulb is a push fit DO NOT try and twist it
Indicator Bulb replacement
First you need to get to it in my 1.2 I can get to them from above however Fiat have kindly given you an access hatch in the arch liner
you need to locate the little cap which holds the Indicator bulb this opens with an anticlockwise twist of about 1/8th of a turn (it is tight due to the O-ring seal) then a pull
this releases the bulb in the holder
To remove the bulb from the holder push down on it and turn anticlockwise and it will pop up
replace and reinsert reversing the above method (NOTE the cap will only close in one position so don't force it)
