I'm a step further in my quest to get my non working remote button key working again ,see https://www.fiatforum.com/threads/getting-the-vin-number-from-the-ecu.491288/page-2 , but I'm afraid that I reached a dead end.
I've taken the key to several lock smiths and none of them can provide a new working key with the remote in it. They can all clone the normal key for around 75 euros.
One of the lock smiths was kind enough to share his experience and he said that quite often the antenna spool will come off the pcb or the spool itself would fry itself. Unfortunately the last was the case. It took some searching but I was able to buy a new spool and soldered on the pcb. After this the car still did not respond to the remote and would not start with the key. Assuming that the key needed to be relearned into the ECU I fired up MES and went trough all the steps.
the last time I did that with the defect spool it would throw an error stating that the key transponder did not function right but now it told me that this key was marked as locked in the ECU and that it could no longer being used. This means that the key is talking with the ECU so the fix worked but because of its status in the ECU can not be used.
It seems that somebody prior to me tried something with the keys and even tho he got an error on the key proceeded to program the ECU with only 1 working key.
Now is the question can I undo the lock in the ECU for this key?
