Thats some beast of a turbo when its next to the engine!
i mentioned it a couple of weeks back. tested on scrap pistons (16 and 8) cut and checked.
was going to use strips of scrap piston but we found out what they are actually made from and used matching filler.
i looked online and seen people weld forged pistons after valve impact damage. people (americans) weld standard pistons to raise compression for use in methanol drag racing.
LOADS of people weld up holes in the pistons of 2stroke engines after melting a hole in the middle by running lean.
all of these are on top of the piston. mine is only on the underside and purely for strength.
sounds good so, and tig is usually very low amp welding so hopefully you should get away with it
