Update:
Mot passed today. first time with the turbo. passed emissions (no cat
In the couple of weeks before the mot it was off the road been treated to a few tweeks.
new handbrake and clutch cables. rear caliper mounts moded to allow the use of cinq hubs rather then the UT hubs (brings wheels in 5 or so mm)
machined and fitted some nylon spacers in the steering rack to stop wheels rubbing 6speed box.
New 6 speed box fitted. MUCH better ratios and a bolted diff ready for LSD.
turbo manifold internally tweaked and turbo raised up (allows better drainage of the turbo)
Boost and intake pipework changed, larger air filter and intercooler flushed out.
New aluminium radiator and coolant pipework changed .
oil cooler finally on the way to been fitted.
Megasquirt updated and tweaked (for emissions
**** New Problems ****
Clutch slipping as soon as boost come on.
Not sure why but will see if it fixes itself (no oil coming from bell housing and clutch is only a few k old (stilo)
If not i will sort it when fitting diff.
