Lo.
Im researching ways to lower the CR of my engine as I want to 'blow it (read turbocharge it).
Acc. to what I can find, theres realistically two ways to do it.
1. New low CR pistons - Pros: its neat and reliable. Cons: Hideously expensive
2. Compression plate and 2nd HG: Pros: Cheap. Cons: Apparently get unreliable at high boost pressure
3. Remachining existing pistons - Pros: Real Cheap (I can do it myself ). Cons: Existing items not forged IIRC, so may cause weakness and pistons may need heat treating prior to being safe to use.
I am trying to avoid option 1 at all costs as its far too expensive. Option 2 sounds OK but unreliable and option 3 is option 3....
Anyone got any experience with using these methods and can anyone advise which is the best way to proceed to lower the CR? FYI, Im looking to pull ~110-120BHp from a 8v 1242 running around 0.4-0.6Bar of boost...
I will be able to play with ignition timing...so that may be of use
