puntodad19
- Joined
- May 1, 2019
- Messages
- 177
- Points
- 101
hi anthony, if you clean down the area around the g/box selector shaft and gaiter, and below, and the inner drive shaft joint area where it goes into the gearbox, and allow to dry, and check the gearbox shaft area every day, to see if g/box seal is leaking......
clutch noise, did your push back the slave cylinder rod and piston and hear any difference in clutch with drawl bearing ??
I assume the the slave cylinder piston and rod are not sticking/sticky causing clutch with drawl bearing continual contact with pressure plate fingers ??
You know that for example, sitting at traffic lights etc. in gear with your foot on the clutch is not that healthy for the clutch mech or the crank, and, starting engine in gear is similar if not worse.......
stop start on lads car, he disables it......wishes it was disabled all the time......
ps some drives rest their foot on the clutch pedal, which is not good......
