Technical  Car isn’t going into gear
Carcurious
England
My fiat punto evo 2010 was struggling to to go into gear and now it’s got worse where I can barely go into any gear at all. Could this be anything to do with clutch fluid? I would rather try and look before I take it to a garage and spend. If so, how would I change it? This is my first time with a Fiat so I’m fairly clueless.
Model
Punto evo
Year
2010
Mileage
120000
Engine? Check if any difference when going into gears with engine running at idle vs engine off. If engine on it's difficult and off all gears work easy it could be hydraulic thing or clutch itself.
As above
If it's difficult to engage gears with engine off I would suspect gear cables
If it only struggles with the engine running I would suspect air in the clutch hydraulics.
How's the clutch fluid level?
I would bleed the clutch, see if it improves (if fluid is more than 2 years old or looking cloudy it needs changing).
I think this shows the bleeding process well:
With engine off it goes into gears perfectly
If you hear gears crunching when trying to select reverse (usually no synchromesh) and your foot fully down, the clutch is still partially engaged , as said most likely down to the system needing bleeding ... at least that's what you need to do first then see what's what
If slave pump is external in your gearbox (little cylinder pressing clutch arm fork) you can see how it's moving when pedal clutch is pressed, it should move aprox 1,5 or 2cm, if less or not moving it's fluid or slave/master pump issue. If moving partially it could be same or clutch itself.
It always crunched in reverse from when I first got the car. Month later now I can’t get into no gears unless the engine is off
Which system needs bleeding? Sorry I’m not very good with cars ?
Then it was already on its way , this kind of fault will usually gradually appear
The clutch hydraulic system.
If you're not mechanically minded ,I'd suggest search for a mobile mechanic, and ask for prices before you book him/her
Disappear? It’s gonna cost hundreds to get it fixed
What will they do after a bleed ?
Let them do the bleed first , could be a clutch slave, clutch master , or an element of the clutch mechanism itself.
There's absolutely no point in trying to 2nd guess the outcome, you could well be all sorted with just a bleed !
