yeah mate that's not a problem at all :0.
muppet42 said:One theory is a seal around the number plate lighting unit. Another is through the boot key hole
ABZSTILO said:Mine did the same thing. You will most probably find it's two things.
The seal for the number plate lights is one (you'll know, the number plate lights will eventually give up) but the seal around the entire boot handle (I found) was worse than useless in that it didn't fit properly.
I removed mine and made a copy from some self adhesive 1mm neoprene sheet I happened to have lying around at the time. Result? No leaking.
I just replaced the number plate lights as they were cheap. I cleaned and stripped the wiring for the lights and the electric boot release which occasionally played up too due to the wee loch forming in the tailgate.......
Daub everything you can with either Vaseline or something similar, button it all up and you'll be fine.
BTW - the key lock on the back door would need to be replaced. Don't bother, it will cost a fortune to do so just blank it off.
H
YcMing said:Can you not put your spoiler on it ?
Andi_F said:Right so is RGZ still blowing at the exhaust though Rob??
If so go to Ming's (if that's ok with Ming) on Monday (Bank holiday) I'll come over an all so you've got extra pairs of eyes....
Anything els eneeding sorted on RGZ?? apart from the Top Mount mentioned on FB?!?!
Andi_F said:Hey while ever my Nan's here I'm wantin to get out the house.....
Anyone got any ideas on how to shut an 84yr old woman up??? she can talk for England.... seriously :earmuffs:
jatkinson said:Remember boys , Chlorofome is your best friend .... just dont let any one find out ......
Martyn said:Werthers Originals. They'll keep her occupied for a bit!
