Calecosse
Bit of a weird one, I've done a rear axle swap on my panda which I've finished and it's now back on its wheels, however, it seems like the axle isn't central. The driver side wheel seems like it's inside the arch a good 5mm or so more than the passanger side. I was going to book it in for an allignment anyway as it hasn't been done for a while but these can't really be adjusted at the back wheels. I was wondering if a couple of mm could be pinched by undoing the 3 bolts holding the axle mount brackets to the floor and nudging them over to split the difference?
Or is it a possibly a poor quality rear axle? Camber and toe seem fairly similar to the eye but someone with the proper equipment would be able to see more. Is this anything anyone else has come across. Mine is low and does have wider wheels on but it wasn't an issue on the original axle.
