imported_abyss113
Established member
- Joined
- Apr 17, 2006
- Messages
- 2,135
- Points
- 377
i cant remember if we changed the belt when we done the head gasket or was it slighlty older ??
Mrcento said:true, because my car won't start at all due to not having a timing belt on it![]()
Andi_F said:Aye but you know what I mean, normally you don't have hold the throttle open Mark.![]()
YcMing said:think is the first time i seen a timing belt on a cento snap like this ?
Ming
Mrcento said:indeed, my car wouldn't bore me with such a trivial issue. it preffers lunching driveshafts, engine mounts, timing belts or gassing me whilst stopped in traffic instead![]()
Andi_F said:aye, you're Cinq does like to make you're life interesting
Mrcento said:well, new timing belt fitted (thanks to Daz for getting it), car running a bit off but i think im either 1 tooth off or the nipple in the pulley isnt seated right.
anyway, i located exact reason why the belt went. you wont believe it. honestly, you wont......
the reason was................................
my drivers side suspension spring it turns out has snapped, a shard of spring flew into the timing belt and ripped it off. was too dark to get pics but i will next time im at it.....
seriously, im begining to have had enough of this. you couldnt make it up
oh yeah, and i found out the slight kink in the sill is far worse with side skirt off....its a full blown dent
what to do, what to do![]()
YcMing said:I'll be selling my lowering kit shortly. But i guess you would need something urgent?
Did the spring cut through the arches and timing belt cover ~~?? It is a really tight angle lol
Mrcento said:oh aye, anyone knpow where to get the black plastic sill trims?
