General  ohhhhhh big problem
humble123
As on my other post with coolant and oil and timing belt it has overheat again and now letting it rest again I think there is a massive problem it would even start every time I try to start it there is a clunk like engine is stuck or locked any advice try to get thought to garage but must be shut help needed
Lee,
try rocking the car in gear, if the engine turns it could be starter motor. I'm assuming the battery is good, also that the clutch is depressed when you're startng to eliminate gearbox issues.
If the engine doesn't turn then, yes you have a big problem. You need to get the car to the garage that fitted the timing belt.
Bad news head gasket has gone is it canny hard to repair yourself or get professionals to do it
It's a more difficult job than the timing belt, unless you've got ALL the right tools and have a fair idea of what you're doing.
