General Odo flashing, aftermarket radio
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
Hi.
Some family has just bought 2008 500, with an android radio.
Odometer is flashing, and I think it's because of this.
Is there any fix for this?
The odometer is flashing because the CAN data bus configuration does not match the stored configuration. Typically this is because a unit is faulty or had been removed. As most Fiat radio are connected to the CAN bus it is likely that the radio change has caused this.
The cure is a proceedure known as Proxy alignment. A Fiat specialist can do this or to do it yourself you need a compatible OBDII interface, adaptor lead and a computer running Fiat specfic software. The most popular is probably Multiecuscan www.multiecuscan.com Even buying the interface and software just for this is likely to be cheaper than paying a dealer to do it.
Robert G8RPI.
I added a double din pioneer aftermarket and did a proxy and all good!
My mileage was flashing after I disconnected my blue me module! It just shows within the software there is no stereo I guess due to the original being removed and disconnected
