CyranoYoshi
- Joined
- Nov 11, 2016
- Messages
- 11
- Points
- 2
Hi there, Cy here and here's a little history on my problem...
Drove a short 10 minute journey to pick up my partner for lunch, was low on fuel so made the decision to top it up after we'd eaten, parked at home for 1 hour and went back to the car to drive her back, turned over but wouldn't start.
First though, out of petrol, embarrassing but possible, so I walked to my nearet garage and bought 5L and a Jerry can, filled it up, turns over but wouldn't start.
Thats when I noticed the clicking sound coming from somewhere in the car, turns out to be coming from the relay box under the bonnet (beleive its the lowest right RED one T9 maybe as it stops if removed), key CODE light is ON permanently and i DO NOT HAVE THE CODE as its second hand.. well 4th I think.
Doesn't matter anyway because even the emergency startup sequence (press accel until engine light flashes) doesnt work, no flashing.
We have removed the battery, tested and charged, don't believe its the issue as all electrics work fine. also hunted for the elusive 'fuel cut off switch' (seriously the image in the manual is USELESS) and think we found it under a panel behind the pedals, although I didn't see it myself a friend did, apparently is IS DEPRESSED).
So to recap, when key turned to MAR, Relay clicks (research points me to fuel pump relay), battery light, temp light and yellow KEY CODE light remain ON. When turned, engine turns over but doesnt start.
MY THEORIES: Battery Fault, Immobilizer Fault, Key Code Reading Fault, Fuel Pump Fault.
1.2 2000 Punto Mk2 W reg, can take pictures/film vids of symptoms but I kinda NEED this car to run as i've only been driving a month and am without a paddle without it atm.
Please provide images or detailed descriptions of any help you can offer, keep it simple.
