Technical Lights on dashboard
2 days ago while driving home, low tyre pressure flashed up, then abs unavailable, hill stop unavailable, esc unavailable, low pressure unavailable.
When I got home I checked with OBD2 reader it is showing no fault codes.
It shows - abs unavailable, hill stop unavailable, esc unavailable, low tyre pressure unavailable when ever I start the car.
Does anybody have any ideas please?
I’ll dig it out a bit. Good chance in ABS sensor. TPMs is based on wheel rotating speeds in Tipo. Good reader should tell you what’s what. Were are you based?
Hi, thank you for the he reply, It was the abs sensor as you thought. I had it repaired in April. I am based in hertfordshire
Had it checked, so the correct part was ordered. The man used a top don reader, it was saying tpms needs recalibration. He done that, light off for now. 🤞🏻
No luck.
No codes showing. Tyres done to bar not psi. Cleared, updated and reset.
Emailed a fiat specialist in Stevenage, who don't have the machine
