- Joined
- Jun 28, 2006
- Messages
- 719
- Points
- 123
Have you got early PGT or UT pads on? There seem to be diffrent pad numbers for these callipers depending on the disc size.
Sei bigger newer styel GT calliper front, larger alloy calliper rear 240mm disc
Cinq older smaller style GT calliper front, older smaller steel calliper rear 227mm disc.
handbrake cable youll need a cento mreg 1995 one not a later r reg cinq or sei as the cable is about 30cm shorter then the older cinq ones
also when bleeding the rear calipes you need to taek the caliper off and jam a disc inbetween the pads to make the bleed nipple at the top or else youll get a pocket of air stuck as the bleed nipple are not at dead top.
my sei has about 2cm of travel on the pedal and can lock the car in a instant if i wanted it to.
a guide said to use the PGT handbrake cable...I thought it was worth a try if it would let me route it neater...no chance.
The sei cable is single piece (i found after i started), the PGT is dual piece and longer. It trvels right up to the handbrake! You may be able to fit an equliser plate and cut some of the body work out, but I'm not doing that.
afraid i can 't remember the length but as the front is jacked up at the mo, i may be able to squeeze down the back and measure. Will let you know
Bump me tomorrow night if i forgot
Kristian
