StanZlatan
- Joined
- Sep 6, 2021
- Messages
- 43
- Points
- 64
Guys what is going on how is the steering wheel turning? I think i am missing something. Is this not using steering belt?
Yes the car is from 2014 and i feel some tension when turning around. I do deliveries so when i bought it new it was very smooth and now i feel like the wheel inside is even touching somethingAre you having a steering problem?
I'd be getting other things checked before the steering such as the top mounts and suspensionYes the car is from 2014 and i feel some tension when turning around. I do deliveries so when i bought it new it was very smooth and now i feel like the wheel inside is even touching something
I am not sure what you mean. I experience subtle slushing sounds and a bit of resistance when i steer the steering wheel very fast or if i leave the it to me steered straight by the stabilizing control after i take a turn.Is this when you are on full lock in particular?
No they are new we changed them last month i know how it feels to drive without them. Old ones were gone now i drive with 1 mile per hour on these evil bups set up on the residential roads.Does it feel any different when you have the steering set on the normal setting and then the urban setting - urban being more assistance to the steering, making it feel lighter.
As Chris said, I be checking all the suspension stuff first as the steering column looks a pig to get out.
The electric steering is known to give problems on our cars but it may not be the column unit itself. Typically a battery in the early stages of failing can be a problem. The steering takes quite a large current draw and can demand it for much longer than, say, a starter motor so really stresses the battery. Monitor the battery voltage with a voltmeter whilst turning the steering wheel. If voltage drops under about 11.5 volts ( although I'd hope to see more) you may be needing a new battery. There is an earth lead from the chassis to the gearbox, under the battery tray, which is known to corrode and may need to be replaced. Also check the battery terminals and lead connections. If it does prove to be the steering unit itself then replacing it with a new unit will require access to a suitable computer tool (dealer tool or Multiecuscan for instance) so the new unit can be coded to the vehicle. Better, in my opinion, to send the old unit to someone like Western: https://shop.westernpowersteering.co.uk/category-264/fiat-panda-eps-power-steering-column.html because, being the car's original unit, when you get it back it's a simple job of refitting it and driving off as it won't need to be recoded to the car. ie. "Plug and play"Yes the car is from 2014 and i feel some tension when turning around. I do deliveries so when i bought it new it was very smooth and now i feel like the wheel inside is even touching something
The slushing sound sounds like it could be water in the car due to blocked scuttle drains(duckbills) which if you look through the forum these cars are well known for it, when I had problems with the steering when the battery was failing one of the main symptoms was slightly heavier steering & also when turning the wheel at all whilst driving it wouldn't re centre itself when you let go of the wheel, it would just stay in the position you had it, a new battery fully cured itI am not sure what you mean. I experience subtle slushing sounds and a bit of resistance when i steer the steering wheel very fast or if i leave the it to me steered straight by the stabilizing control after i take a turn.
Do i have to wait for it to show up?No mention of a RED steering wheel symbol on the dashboard...??
Does the Red light show before engine starts?Do i have to wait for it to show up?
Yes and then it goes away.Does the Red light show before engine starts?
Ok..Yes and then it goes away.
