General how about a warm welcome for our newest 20 valver
bulldog5046
faster! FASTER!!!
:D yes yes, calm down, i do now happen to own a metalic dark blue fiat marea weekend 2.0 20v :D
needed a new gaskey on the exhaust manifold, cost me £390 (y) its quite a minter, full leather interior (y) :D
custard
Status: DEFCON Grumpy
Edinburgh
lot of car for the cash :D
wouldnt mind one as a second reliable car ;)
OP
OP
bulldog5046
bulldog5046
faster! FASTER!!!
well if it isnt after i replace the gasket i have another engine lined up for £250 :p
chrisunoman
Prominent member
Manchester
You got a bargain because its got a leather interior!???!!!! Sounds like youve got your priorities wrong!
Steven
Go on the Fiats!
Northern Ireland
I reckon this one was worth a punt. He'll easily make what he paid back if it's shot and he has to break it.
Steven
Go on the Fiats!
Northern Ireland
AppleSei said:
The wife and kids will look snug inside it.............
Says the Sei driver! The only way your Cento would keep up with that car is if it was loaded into the boot! :slayer:
AppleSei
RIP L181 VBB
West Yorks
We'll fit your sei AND panda while were at it ;)
I never said it was a bad car.......
In parts alone its worth what ryan paid, and it has had an engine replacement, so its got plenty of life left
custard
Edinburgh
your . button seems to be stuck...................... ;)
chrisunoman
Prominent member
Manchester
It will be interesting to see how much it costs to fix.
Dont think im having a go, its a lovely car and a potentially good buy, but imo it will cost a fair bit to put right.
custard
Edinburgh
could cost,but if its just the manifold blowing then its an easy and relitivly cheap fix
OP
OP
bulldog5046
bulldog5046
faster! FASTER!!!
that should be corrected by fixing the gasket, if it doesnt then i will opt for engine replacment
Hellcat
zombie nation
on the A684
Replacing the exhaust gasket won't fix the low compression, its either piston rings, something wrong with the valves or a leaking head gasket.
Not sure what you have to do if you replace the engine. Obviously the VIN numbers won't match. But since you're not changing the type of engine.. Hmm dunno
The alternative option is remove the plug and run it as a 16v 1.6 :p
Looks good though. It got any other issues we can help with?
OP
OP
bulldog5046
bulldog5046
faster! FASTER!!!
not really hellcat, just need to fix the gasket and see what its running like....
hmallett
Mr Pedantic
Wales
Yup. An exhaust valve cracked on my Coupe. It cost me about £300 to get it replaced. If it's a piston, it's more like £500. Head gasket will be cheaper than both those.
I think that if it's the head gasket you usually got low compression on two adjacent cylinders though.
H
