Mushsgirl
Does your blue & me still work? Probably not if the mileage is flashing. If it's not working, detach the battery earth for 5 mins and the re-connect. Quite often does the job
Is the blue and me the microsoft media connection??
Yep press the phone button on the right side of the steering wheel. If nothing changes in the centre display the blue& me has stopped working but just try the battery dissconnect, usually works
My usb memory stick is still playing my music?
do you get messages on the dash panel though..??![]()
It's still giving me the song names, just about to go out in her so I'll check the other bits ?
Needs to go on a diagnostic lap top then to find out what's causing the mileage to flash. The other common thing that makes the mileage flash is low battery voltage. And I know you've already had battery issues. I would get someone to check and make sure your alternator is connected properly
I'd still have your alternator double checked to make sureThanks, I have been told that the battery they put on should be higher, what is the recommended battery size for my car?
Build a bonfire.Right back again, I'm back to the garage tomorrow, yet another problem. When changing gear I've got a lot of lag, rev counter stuck on around 2 to 3 thousand revs and car won't go any faster then power suddenly kicks in and zoom! Ffs had enough now ??
**** girl.. u have problems..Right back again, I'm back to the garage tomorrow, yet another problem. When changing gear I've got a lot of lag, rev counter stuck on around 2 to 3 thousand revs and car won't go any faster then power suddenly kicks in and zoom! Ffs had enough now ??
Egr valve sticking open.?
Dpf regen in progress.?
Any warning lights.? Any smoke from rear.? Was the engine running smooth when it occurred.?
Did we mention dirty EGR valve. I can't remember now aw we are on page 14 or 15.. lol
So I recon u have a dirty EGR valve and a wonky alternator....
