Technical Brake Switch issue
Webby003
Doncaster, UK
Hi all,
I have a 62 plate 500.
Had a few issues with it for last few weeks been trying to fix...
Daytime running light was out, so fixed that, but on top of that started getting a "check engine" warning, borrowed a "computer" which said the fault was ABS / Brake Switch.
Planning on getting this resolved but while i was looking for the brake switch i found a few cables in the drivers footwell...in other words just loose... any ideas?
In addition i have now also discovered by full beam doesnt work, no warnings to say this and blue light comes on dash when trying to use them but not coming on.
Any help would be appreciated.
(Picture attached of the cables "loose"
Model
1.2 Fiat 500 2012
Year
2012
Mileage
58000
Hi all,
That yellow disconnected wire looks like it may be Airbag side, so be very careful!!!
What is the history of vehicle?
These check engine warnings need resetting. Somtimes thats all that is required. Particularly if it been worked on before hand.
What specific codes are showing.
ABS is unlikely to cause check engine warnings. All does not sound as if its as it looks on this occasion.
Thanks for the replies.
So current warnings on dash are...
Stop Start unavailable .... check engine ...
The history - had a bump on the front about 3 years ago, but nothing with these issues until last 2-3 months.
@The Panda Nut
@bugsymike
@The Panda Nut
@bugsymike
So they may be unrelated to your current problem, however if that yellow thick wire is Airbag related be very careful, it does sound like the accident repair may have been a little sus, possibly.:(
By the way how good a diagnostic tool used to read error codes?
Stop start unavilable sounds like battery may be at the bottom of it. Check backandcsearch on stop start in the 500 and Panda forums as theres ben a great post this year on this which may help you. I think that related to the clutch switch among other things.
I find there are many odd wires just hanging about. May be best not to waste time on this. Other countries / different specs use them.
Not sure, it was a friends / neighbour and he is really handy with cars takes them apart etc so assuming it would be a decent one.
The accident repair was over a year ago, this issue has happened in last few months... could still be related?
The yellow cable i couldnt see where that could go, but the multi colour one seemed to be just outside a black box with the exact same shape on this with nothing plugged in.
Didnt want to plug it in in case it did anything but seemed odd it wasnt connected,
Tricky.
Re the error codes many on forum use MES which is Fiat specific and if you have the full version it will give lots of detail.
Update :
I have bought a brake switch off a wreckers yard put it in and it’s still showing “warning check engine” so going to see about getting a MES Diagnostic tool.
Update :
If you can go for the full version and correct leads it should be able to give all the details of any error codes stored plus it can give "live data" etc. and activate various parts as well.
