Thought for the day..
If you have a dual or tri motor setup can you run different gear ratios on each motor?
Probably a stupid thought but this is not reciprocating motion we're talking about so if one motor drops out of it's power band doesn't necessarily matter if the bearings could take it as long as it doesn't become drag.
Acceleration the lower geared motor does the work, top speed the other one does, at a cruise they both chip in.
No idea if this is a thing..just a thought on my lunch time walk.
If you have two motors you can design the motors for different applications, so have one that’s more efficient running at a high speed and one that works best at a lower speed, the. You can combine/blend the two motors to result in best performance you don’t generally bolt the output of your motor to the wheel you’ll have some sort of gearing normally, even if you did bolt the output of the motor to the wheels the gearing is one to one.
I think Tesla do this with there dual motor set ups, one is best suited to setting off and low speed acceleration and the other motor is better suited to carrying speed. Electric motors are not like engines they don’t have a narrow power band you have to sit in the middle of, but if you have an electric motor that works best between 0-16,000 rpm, obviously your wheels won’t be doing 16,000 rpm so you design your gearing to match the desired speed of the car compared to the output speed of the motor.
You might have one motor that is 70kw for doing most of your acceleration and stopping, then you have a second motor that is also 70kw which is geared to kick in over 50mph to provide extra power and acceleration when needed, this is more efficient to use two smaller motors that you can switch on and off, than having one massive 140kw motor than would use much more battery power at 20 - 30mph.
If you have two motors it’s more efficient to have one geared lower and one geared higher then you can run your second motor at lower rpm using less power but you still have your other motor geared lower for when you slow right down or stop and start.
As I said it’s a bit like having a V8 engine and all the power of a powerful V8 but then you turn off half the cylinders when you’re doing 20mph and in essence have a standard 4 pot. The gearing on the motor is for energy efficiency rather than keeping anything in a power and because as an electric motor gets faster the power (BHP) increases and the torque stays the same.
If you put a gearbox in an electric car the benefits of the gearbox would need to be outweighed but the weight gain, if you’ve got two motors you’ve got two gears and your then not adding any weight.
