General Front subframe wows
moxon508
View attachment 471037just taken it off my 1.3 multiget cross.
Does this look salvageable. I have been over it all with a heavy chisel. A oil leak looks like it has preserved the centre.
Model
Multiget cross 4x4
I'd replace it if I could, its part of the crash structure, it's designed to fail in a predictable way dropping the engine down instead of pushing through the car
To get somebody to weld it properly is approximately £425
But you may not have an option, last time I looked for a rear one they were only available in Italy, no idea on the availability of the front
A garage i went to quoted £2k
To cut the sill off and rebuild the inner sill, jacking point and C pillar, plus painting is £750 per side
That roughly twice the work, than I can see in the photos
£2k sounds wrong to me, unless it's worse than the photos show
I am hopeful a new one can be found
Out of stoc
But at least they are made
If that 51857821 is the part number then:
It mentions 51857821 in the listing
? :unsure:
? :unsure:
Listing is wrong
Does not fit the 4x4
51857821 is right number
