Thank you, I’ll check up on themLooks like all the petrol and diesel 4x4 pandas share the same 51882569/51857821
cross rail
Baxenden Car Breakers ltd are breaking a 4x4 on eBay, no idea it's state, might be worth a phone,
We’ve seen some abroad but stupid delivery prices are the issue, thank you. I’ll just need to keep lookingI can't find any new for the 4x4
It's not listed in the klokkerholm, prasco, lm axles catalogues
Doesn't help it's not always called the same
X member
Front support
Cross frame
Front subframe
Plus more and combinations
Can find several used in Germany and Italy but postage will be a killer
Can the original not be welded ? Not ideal but has been done before, due to scarcity of parts
51882569/51857821So which part numbers are you using?![]()
As per post 2Do you know where the "Cross" FRONT subframe differs from the 2WD Pandas?
The bottom arms are the same as 2WD so it's fair to say the mounting points are the same. It should(?) be possible to get a 2WD subframe modified presumably to clear gearbox or some such.
I'm not saying this is "the best" way forward but it might be the only practical way when the correct part is not available. I can help with pictures if needed.
