General  1.3 4x4 front subframe
moxon508
Hi, does anyone know if there is a video showing the removal of the panda 4x4 front subframe. I need to take mine off to see if it is salvageable. Cheers
Not seen any videos
It's pretty simple,.except the front exhaust needs dropping on a 2wd petrol
you leave everything as it is, and only unbolted a few things, steering rack, ball joints, drop links, and it drops down with the anti roll bar and suspension arms still attached
Might be worth removing the arms while it's still in the car if you want to see that area
Can't see the 4x4 being that much different
Cheers. I was wondering if I needed to support the engine if a mount was attached to it.
I don't bother on the 2wd, it's still got both the right engine and gearbox mounts attached to the chassis, the main engine mounts
You may have to remove the, or loosen the bottom dog bone one for the exhaust, on a 2wd this can be changed without supporting the engine
The 4x4 has a little extra weight rearward, but some of this is supported by the centre bracket,
