What is the resistance between the small wire and the case of the alternator
Are the symptoms different, straight after changing the alternator
Was the original problem just a flickering battery light, followed by it being permanently on, followed by flat battery
You don't have to crawl under the car you can use this connector
You can tell if the coil pack is getting a control signal and giving a good spark like this If one is weeker and the spark does not jump as far than the others it's suspect It is possible to get a jolt if you do something wrong, probably not a good idea if you have a pace maker As long as the...
www.fiatforum.com
www.fiatforum.com
As long as there's no corrosion, engine and gearbox clutch are fine, almost everything else is repairable at a resonable price
