Technical  Front end creaking over bumps
Cork
I've had an intermittent issue with the Panda (1.1 Active Eco) and some creaking noise (kind of a squeaky creak?) from the front end, which is most pronounced when going over speed bumps i.e. the whole car is pitching. Rocking the car by hand from the side doesn't really make any noise. It seems to go away when it's wet.
Based on some searching here, could it be the anti-roll bar bushes? The drop links look fairly new, as do the springs/shocks (although off-brand). I don't feel any obvious play when I lift the front wheels. I guess it would be easier to determine if I disconnect the drop links?
Model
1.1 Active Eco
Year
2010
I had tried that a few times with silicone spray or WD-40 and I never really got anywhere with the intermittent nature of it. I'll try soapy water though, thanks.
Thanks for the suggestion. It does appear to be the lower control arm bushes. I guess the only option there is to replace the whole arms? Any recommendations on brands?
Here in England I find if i buy from a local motor factors there normally okay, they don't want you turning up at their counter for a return
I would stay away from febi, there rubber parts in general have not been the best quality, we have also seen there thermostats fail
Last ones I fitted I bought as a pair on offer, Can't remember the exact price, was over £30 but under £40, and got a couple of quid back on the old arms as scrap
For that I got 4 new bushes and two new ballpoints
I have replaced just the bushes about a fiver each in the past, but there's a lot more work involved, worth it on some car where the full arms are expensive, last time I checked it didn't make sense on the panda, Depends on budget, time, tools available and so on
Original Birth from Shop 4 Parts have been good to me.
Make 100% sure the ball joint pin clamp is locking tight onto the pin. Mine was bolting up but leaving the pin loose. I had to replace the whole knuckle.
My car came a couple of years ago with lower arms where the rubber inserts had become totally detached (God knows how it had passed an MOT) and I fitted a set of Original Birth arms, bought from Shop4Parts. They seemed fine, but more recently, road noise has become a real bugbear, so I replaced the Original Birth arms with premium Lemforder items which seem to have much more compliant rubber inserts - not much change in road noise but the car's handling, steering and general quietness of the suspension over bumps is dramatically improved. In the greater scheme of things, I think the Lemforder arms are superior value, despite the higher (but hardly excessive) cost. For cost-conscious owners, the cheap arms are of course safe, and functional.
I wonder if your loose pin problem was a result of someone being heavy handed with a chisel/screwdriver to open up the lower knuckle bolt hole to release the locking bolt, something that I've seen done on many YouTube videos. A carefully deployed ball joint splitter separates the lower arm pin from the iron knuckle without any drama.
I was recommended TRW parts, which seem reasonably priced (around €75 for two lower arms). I guess I should get a ball joint splitter too.
Nope
Do one side at a time so the anti roll bar is helping you
Undo all the bolts, heavy hammer helps
Smash down with a 2 1/2 lb or greater club hammer and it will drop out
The bolts need tightening with the wheels on the ground
Be careful with the torque of the pinch bolt, early Haynes manual and some online resources quote it wrong, copied and pasted from the later models which use a larger bolt
Piece of cake, less than 5 minutes once you done one and if you have the right tools to hand
The pinch bolt, undo the nut and drift the bolt out, if it's corroded together and you use a breaker bar on the bolt head side, you risk twisting the head off, I never broken one but other have,
Nut should go to the front of the car
Drift the old bolts out and scrap them. Fit a new high tensile bolt with plenty of anti seize paste. Shop 4 Parts sell the OEM bolts for not very much.
Use an old screwdriver to CAREFULLY open the clamp, otherwise you will not get the ball joint pin out of the hub carrier. When the new arms are bolted up make sure the pins are fully clamped. My Multijet had been used with a loose clamp. The hole had worn so much that it could not clamp the pin. I had to replace the hub carrier.
Thought I would provide an update - it failed the NCT (MOT equivalent) on front suspension imbalance. Shocks and shock top mounts were replaced. No more front suspension noise, and much improved ride. I heard afterwards that the top mounts can be an issue with these cars, though I didn't know how to check for play in them - I saw a YouTuber jack up the front and try and move the wheel vertically.
I've done this many times in the past in search of sometimes questionable savings, usually resulting in much frustration and swearing.
Now, I'd only take on lower arm bush replacement if I had a hydraulic press and the tooling to go with it. Even a heavy duty well secured bench vice might leave you struggling. If all you've got is a few blocks of wood, the floor and a big hammer, it's probably not going to end well.
I weighed in the old knuckle so can't go and check, but there was no obvious damage. However, the clamp "bore" that carries the ball joint pin looked OK and I could get a stiff feeler gauge into the gap when it was tightened. I got a pair of new bottom arms after the failed MOT and then found the new pin was not being clamped.
The M8 pinch bolt tightened up solidly (I always use new high tensile or OEM). I cleaned the slot with a grinder and slitting disc while the arms were off the car. It was already clean and YES, I was very careful to not nick too deep. Despite over tightening one bolt, the new ball joint pin was not getting clamped. Some shim steel fixed the problem (at expense of suspension geometry) for the MOT.
A new (used) knuckle permanently solved the problem. I assume the car had gone many miles with a loose or stripped clamp bolt.
