Mot time coming up for our 1.1 2009 Panda, so thought I'd better check the rear brakes. first indication of an issue was the handbrake balance bar was at an angle, so popped the wheels and drums off, low and behold, one of the auto adjusters had fallen to pieces. the shoes looked ok but decided to fit new replacements anyway along with new springs etc. I then checked the wheel cylinders, to find both where leaking on one piston and siezed on the other, so a new pair of wheel cylinders ordered. I removed the wheel bearing/ hub to find that both ABS sensors were damaged, so ordered them. next remove the original brake lines from the wheel cylinders, guess what, the pipe snapped, one at the wheel cylinder, the other at the flexi join! I didn't have the right fittings in my brake pipe making kit (must order some more) so ordered 2 new ready made cupronickle pipes just in case. Next remove the backplates to get at the bolts for the wheel cylinders (stupid design) you guessed it one allen bolt each side siezed and rounded, had to cut the heads off to remove the back plate, one thread came out easily, the other was rust welded in, after many attempts with heat easy outs and so on, removed the stub axle (that was fun, all the studs came out as the nuts jammed on the threads), so that I could drill and tap the thread out, in the meantime the I ordered a 10mmx 1.25 tap and die set to clean out the stub axle threads and studs. with the storm blowing through had to get the wheels back on and the Panda back on its wheels just in case. Today I rebuilt both sides, made up the new brake pipes fitted the new ABS sensors. cleaned up and undersealed the rear axle. ready for bleeding the brakes. Only to find my Eezibleed cap has split in it evidenced by a jet of brake fluid hitting the bonnet, tried another cap that blew off under pressure spraying 1/2 liter of brake fluid everywhere. I'm a bit cheesed off to say the least, what was supposed to be an afternoons work has turned into 3 or 4 weeks, so far, of trials and tribulation, anyone tried vacuum bleeding the brakes?
