Technical  Fiat Panda engine turning
badenjan
Secunda
Good day.
I hope you guys can help me.
While I was driving from one town to another uphill, my car suddenly just stopped working, the rev counter dropped to 0 and does not want to start. I have checked the timing belt and was still in place. engine only turns.
I have used an OBD scanner and it shows P0335 crank sensor position a circuit.
So I have done the following:
Replaced spark plugs
New cam sensor in
New crank sensor in
Checked timing marks of timing belt. still in place.
checked battery - still good and voltage still good
replaced Ignition coil
And still the engine only turns and the same error comes up. even after resetting.
What else can I check
Any chance the wiring to the crank shaft sensor is damaged?
I had crank sensor go on a 1.9td Doblo after 20 minutes cooling down I was able to drive home which is quite common .
I have had Punto wiring rotted through at the ECU plug, wire broken inside plastic sheathing so took some finding.:(
I will have to check for that
What year and what engine? There is a known problem with ECU plugs and associated wiring coming loose on the smaller engined version. I've seen pictures where people have put cable ties around the ECU plugs to make sure they are tight into the ECU.
Fiat Panda 1.2 Dynamic 2007
Does the rev counter move while cranking
Does your scan tool register any revs
Great signal not seen by ECU
Are all the other warning lights okay
Is the oil, battery, engine check light all lite when you switch the ignition on
Does the immobiliser light go out
Do you hear the fuel pump prime
oil, engine lights all lite
immobiliser light still on
do hear the fuel pump prime
Great
The ECU will not do anything, no signal from the Crank sensor
The P0335 code hints it's not just the key
Do you have a test light or multimeter
Do you have a spare key
Great
i have a multimeter, will test tomorrow morning. bit too dark now
I do have a spare key
Great
Meter on volts but one lead on the battery negative and the other on the engine block
Crank the engine
Voltage should remain under 0.2V but under 0.5V is still fine
Here's mine with a faulty earth and the block is going to battery voltage while cranking
And he immobiliser light stay on
So a good place to start
Great
Crank the engine
okay, now my immobilser light goes off, but engine light stays on
Great
Crank the engine
voltage 0.1
Engine light should stays on until its started
Is the oil pressure light going out, very quick while cranking
As soon as you stop cranking is there a delay before it comes back on
Does the battery light go out as you are cranking
lights still on. normally it goes off when engine runs, but cranking stays on
