tiaf 005
Hi guys n gals ive recently had a Fiat 500 1.2 8v 2013 model recovered to my house in need of a timing belt kit and water pump fitting.... Easy right ! Here's where it gets interesting...... So the previous guy doing the work for some reason removed the timing belt without locking the camshaft/crankshaft into place and the sadly got covid and passed away ! Anywho the engine has rotated and the timing at this point is any ones guess (sigh). Ive got both the cam locking tool and the crank locking tool but what i cant find anywhere online is a guide for the timing and since this engine has NO marks im stuck. If i find tdc on cylinder 1 which i presume is the one closest to the timing belt then the locking tool doesn't line up up with the holes in the crank ? Also how do i determine where the cam shaft needs to be since again theres no marks just the plate that slides into the end. So simply put all i want to know is how to start again and make it right. Cheers everyone
