cskerry87
Afternoon all. I'm new to the forum and hoping for a bit of expertise if anyone would be so kind. Please forgive me for any etiquette mistakes, and I'll try to keep this as concise as possible while providing some background:
Last week I changed the timing belt and water pump on my wife's 500 (2012, 1.2 8v, Euro 5 engine). I followed a combination of Youtube and Haynes manual, and have changed cambelts successfully on my own cars in the past.
I completed the job using DIY timing marks on the sprockets and block (gold sharpie works a treat, by the way) and did not lock the crank or cam shafts. At the time, I didn't notice the advice in the Haynes manual to slacken the cam sprocket before tensioning the timing belt, so the sprocket stayed undisturbed and I finished the job. I rotated the engine by hand 2, 4, 6 and 8 times, and my marks realigned perfectly.
The engine started and idled fine, but when I ran the engine up past 3,000 rpm I got a shuddering misfire and a flashing engine management light. My little OBD reader flagged up "multiple misfire, cylinders 2 & 3". The funny thing was that as soon as the ignition was switched off and the engine restarted instantly, the idle once again ran fine and the EML had disappeared.
These symptoms repeated almost every time I ran the engine revs up beyond 3,000.
So, I thought since I hadn't used the locking tools when changing the belt, I had better order the tools, strip everything down and check the timing. I did so, and the timing tools fit on together with the belt in place, suggesting the timing is spot on. Hmm.
The only other thing I hadn't done originally was to slacken the cam sprocket before tensioning the new belt, so I thought I should do so now to eliminate that, before looking into coincidental problems with plugs/coil etc.
Here comes the cock-up...
My engine is a Euro 5, which has what I now know to be the VVT cam sprocket with the brass-coloured cover. Unfortunately the Haynes manual mentions nothing about the VVT mechanism, and only says that on Euro 5 models the sprocket retaining nut cover needs removing.
I struggled to slacken the central torx nut, so very stupidly decided to remove the small torx bolts around the edge of the cover. When the last one was out, of course the cover sprung off and dropped a load of oil, and the internal spring released its tension (albeit the spring is still in place). I then notice the small text on the cover: "do not remove cover" :bang:
If you're still with me I thank you for your patience! The upshot is a few questions:
1. Is it possible to reattach the cover to the VVT pulley, or am I screwed and will need to buy a replacement pulley?
2. If I do need to replace the pulley, does anyone have any advice on the fitment process? Is it as simple as removing the central torx bolt, sliding the old pulley off, sliding the new one on and torqueing the bolt up? Or does the new pulley need "setting" in a particular position somehow?
3. Is it actually important to slacken the cam pulley before tensioning the new timing belt, or was I just on a wild goose chase in that regard? My timing marks lined up perfectly following tensioning, and obviously the timing tools confirmed that the shafts were in the correct phase relationship, so should I have just left the pulley alone? And if I fit a new pulley, should I leave it slack until the belt is tensioned?
4. If I get the pulley issue sorted and the belt back on and am happy with the timing, does anyone have any ideas to explain the misfire? Surely it's too much of a coincidence to have a faulty coil pack or plugs immediately after the belt change?
Sincere thanks for reading if you've got this far!
Stay Safe
Chris
Stay Safe
Chris
