roombacurious
- Joined
- Sep 26, 2007
- Messages
- 2
- Points
- 1
I've read a few relevant threads on this forum but I'm unclear whether I'm having the same problem myself.
I have a 1997 1.1 Punto 55 which is behaving as follows:
- It will not start when cold unless you press the throttle a bit whilst turning the key and keep manually revving the engine until warm. If you stop at a traffic light when cold, the engine is likely to switch off.
- When warm, it will rev up and down usually between 1,500-2,000 rpm when idling. Once it did rev up to over 3,500 rpm but stopped and return back to 1,500-2,000 when I hit the throttle again.
Additional info:
- The problem seems to have started when the front part of the exhaust (before the catalyst) started making noises. It was replaced and the noise has now gone away.
- The head gasket has been replaced in December last year (overheating) - the car had been working ok since.
- There are no warning lights coming up.
Any thoughts on my case?
Many thanks,
George
Additional info:
Many thanks,
George
