PuntoELX01
Hello guys,
I am just started to get to renew my grandfather's Fiat Punto ELX from 2001 1.2 8V, it had been almost 3 years without working (since he's gone) and now it have some issues to take care of.
I already had changed battery, coolant radiator, the spark plugs, crankshaft sensor, coolant liquid, motor oil and filters (it doesn't have a fuel filter, it does but is inside the fuel pump and here I can´t buy just the filter) but I still got two problems that I'm not getting to solve: in cold it doesn´t start good, I mean it is hard to get it started, I have to rotate the key 3 or 4 times until it starts and there is where the other problem comes up, if I give full throttle the rotations decrease to less than 500 rpm (idle rotations: 850 rpm +/-) and the car seems to choking, almost turns off and stays like that a little and then it accelerate normally (i already have bought some injector cleaner and 98 gasoline with additives because before that if I hit the pedal to the metal the engine turn off as soon as the throttle went to the max), but if I hit the throttle gradually the car seems to have nothing.
Does someone had this problem? Or can someone gave me some help on this?
I thank everyone in advance for their help.
Regards
Regards
