Fredastaire
- Joined
- Dec 19, 2017
- Messages
- 450
- Points
- 133
Notes | |||||
1 | Comformatic | ||||
2 | Sooty exhaust | ||||
3 | P0401,P0402,P0238 NO 236 | ||||
4 | TAC only 50% Cheesemonster 90% | ||||
5 | LPEGR cooler temp max144 mean100 | ||||
6 | LPEGR valve controlling OK? |
I tested the turbo solenoid, thankfully it was working ok. I purchased and fitted a new one 10 days ago. I also tested the old as I still have it and annoyingly that works as well.@BoultsG
So what does this all mean.
Notes 1 Comformatic 2 Sooty exhaust 3 P0401,P0402,P0238 NO 236 4 TAC only 50% Cheesemonster 90% 5 LPEGR cooler temp max144 mean100 6 LPEGR valve controlling OK?
DPF is cracked but not enough info to conclusively say cooler is blocked. (contradictory evidence)
The codes with no 236 and Cheesemonsters info on TAC points towards turbo values not as expected.
TWo things i think need checking
1 a good long run with T4.
2 test the turbo solenoid as
PS i forgot to mention the injectors but info from next run will help.![]()
Turbo solenoid test
This discusses the option to test the (turbo solenoid)boost valve in MultiEcuScan.www.fiatforum.com
If the EGR opening is mainly shut or wide open then the cooler ought to be carbon blocked.
However, maybe first remove and flush out the intercooler AND remove and clean the MAP, (not sure what aerosol cleaner to use
We have a long ( 90 minute journey tomorrow mostly on the motorway) so I'll run T4 and post it later.
Thanks for the feed back, I’ll check the previous posts from @Fredastaire and carryout a bit of cleaningIm now away for a while. Ive had a look at the raw numbers (no graph capability) and lpegr cooler
Max 159c mean 110c valve openings mostly min to max but some intermedeate. So not indicative of blocked lpegr cooler. So it back to the dity stuff remove MAP sensor an clean intercooler. This may be the one occassion that a 401 actualy means the hpegr valve.
Thanks @FredastaireFor the HP EGR you can use multiecuscan and watch the desired opening and the actual opening and see if they tally. If you remove this EGR then it's straightforward to clean with Caustic, I can tell you how.
The way it operates is that there is a electric motor power drive to push open a valve, very much 'penny on a stick' like a car exhaust valve. It has its own return spring. My opinion is that if carbon on its spindle jamms it then it would be held open, the motor drive would retract being oblivious to the fact that the valve itself was stuck open.
Stepping aside, there have been cases of carbon blocked inlet manifolds.
It also advisable to check the air filter, it's a known problem for mice to nest inside and fully chew up the cardboard filter material.
