Technical Ducato 2.8 won't start
Sorry about my absence been away from the beast for a few days.
I've now ordered and am waiting to receive a new pressure regulator which I'll fit on Tuesday/Wednesday of the coming week.
Since my last post I've had the cover off my ECU and inspected the male and female connector's which like the other parts of this vehicles electrical system appears to be in immaculate condition and shows no sign of damage or corrosion. The next episode of this riveting saga will be posted Wednesday or perhaps Thursday of next week.
It would seem I've not answered a couple of questions posted earlier in this thread please except my apologies.
The fuel filter is a metal canister type as to egr valve I don't know what I'm looking for or where .
A pointer in the right direction wouldn't go Amis's.
Once again many many thanks for any and all helpful comments
I have noted the fuel filter as metal cannister type. As regards the EGR I believe that this was an option. If fitted there will be a debimeter (air mass flow sensor) with electrical connection in the air filter output hose. Also please see attached diagam, in which the italics are mine, The diagram is looking at the rear of the engine. The cooler (3) is mounted over the inlet manifold, and the valve (5) is towards the RHS of the vehicle.
I hope that the new regulator works for you, but you are jumping two steps at a time. Testing the regulator and wiring would have been easier than changing it.
Please do be aware that the hp fuel system operates at up tp 1350 Bar, or 19580 psi.
No unfortunately the new regulator has also made no difference.
And there appears to be no egr valve present.
Wiring diagrams and pin outs would be most welcome.
New fault showed up tonight
I have attached what I hope are the correct wiring diagrams for your engine, annotations and corrections are mine.A also included are pinout for ECU, and my colour code chart. More information is available online here. However some of the other diagrams are unreadable, and main description texts are cropped. See diagram E5050 - 2b for hp regulator, and 3rd piston solenoid.
The new fault appears to relate to the hp pump 3rd piston deactivation solenoid. It is the other electrical device on the hp pump. Possible causes include wiring/connector being disturbed, rodent damage, low battery voltage, severe cable harness damage due to long term dampness (internally corroded wires have been reported, which is why I suggested a continuity check for elimination).
  • eLearn E5050-1a Engine Management Canister Filter.pdf
  • eLearn E5050-2b Engine Management without EGR.pdf
  • Ducato 2.8 JTD ECU Pinout.pdf
  • Fiat Wiring Colour Codes.pdf
Had to walk away from this for a while .. back at it now have removed ECU and immobiliser and sent those along with both keys to ACtronics in Kent last week.
They have informed me by email that a couple of faults have been found and rectified it's due back in the next couple of days I'll keep you all informed as to my progress or lack of.
Once again many thanks for any and all advice
Ok all's well (fingers crossed).
Many many thanks a local mechanic thanks very much Lewis.
The beast wouldn't start because there was a couple of faults within the ECU how or why it developed these faults I'm afraid I can't shed any light upon.
I removed the ECU and the immobiliser and sent them along with keys to a company called ACTronics who serviced/repaired my ECU for the princely som of £255 and low and behold it's alive again.
Thanks very much for the advice and encouragement to one and all.
All's well that ends well...
Pleased for you , I bet you are glad to have it back on the road again.:)
