Technical Ducato 244 2.8 jtd alternator replacement.
MKUser
Hi, I want to replace my alternator.
It's beginning to fail.
I don"t know very well how to proceed.
There's not very much space to work on.
Anybody who's done the job?
Thanks a lot
How do you know that the alternaror is begining to fail? What are the symptoms?
Sometimes it marks 13,2V
Other times 12,8V.
Each time I start the engine voltage is different but never 14 V.
I think it needs to be replaced but I don't how to do it .
Other times 12,8V.
Repair or replace? Repair would be difficult with alternator fitted to vehicle.
Raise the vehicle to improve access.
Disconnect the battery negative.
If vehivle has aircon, then compressor drivebelt will have to be removed for access.
Remove electrical connections from alternator
Loosen alternator fixings, and slacken alternator belt adjustment, and count number of turns (not easy).
Remove alternator belt.
Remove tension arm from alternator.
Remove alternator main fixing bolt.
The really difficult part, remove alternator from vehicle. I belisve that this has been done and mentioned on forum.
Here is a link to the eLearn procedure which also does not tell you how to remove the alternator past all of the obstructions.
Good luck
Good luck
Thanks...I've seen the elearn .
The think is what you say.
What I have to remove to take off the alternator and put the new one.
Hi, I have accessed to the alternator and I've got a doubt.
There's no screw head.
Don't you think??
I've taken pictures so I hope we can see the downside alternator where goes a big bolt attaching it but I don't see the head.
How may I remove this bolt??
