If top and bottom radiator hoses are the same temp and the two heater pipes going into car at bulkhead are similar then hopefully OK.I don't know how I would know. Pipes around the thermostat are all hot.
The old one wasn't working though either.Make sure to get original temp sensor and over heat switch back from garage.
Refit the old sensor and over heat switch.
Some aftermarket gauge sensors are very poor indeed.
If no obvious bleed screw, two things to try.PS @airwave ... i cant see a that coolant system bleed screw anywhere near the heater pipes and wiper motor on mine. Do you have any pictures of one at all?
In the old days we used to have a Smiths Instrument tester for fuel and temp gauges, but these days most is done with diagnostics.Is there a way to actually verify the temp that the sensor should be feeding back to the guage? This will at least tell me if it is in fact overheating, which I'm still not 100% convinced it is, I'm leaning more towards some issue between the sensor and the guage itself.
Ahh i do have an infrared temp gauge somewhere for my pizza oven thing. So if i point that at the brass body of that sensor, it should basically give me a similar temp to what's on the gauge if its working correct.In the old days we used to have a Smiths Instrument tester for fuel and temp gauges, but these days most is done with diagnostics.
I know on some Vauxhalls they don't use a gauge which annoys me as I think it important , but when hooked up to a diagnostic tool it shows engine temp.
Other than that some form of Laser temp reader that you point at engine, as I mentioned before I believe, I test thermostats in a pan of water on stove using a suitable thermometer. I did try a normal houshold one and blew it off the scale in the past.
As a very rough guide if engine temp normal 90 degrees Centigrade and I grab a top hose to the radiator I can only hold for about 30 seconds before unbearable.![]()
You could point near sensor but also above where the engine thermostat is fitted towards top of engine on metal part at highest point that water goes through/around, also where top hose joins the radiator.Ahh i do have an infrared temp gauge somewhere for my pizza oven thing. So if i point that at the brass body of that sensor, it should basically give me a similar temp to what's on the gauge if its working correct.![]()
The 2.8idTD only needs one temperature sensor for the gauge. A high temperature thermostatic switch for the warning light is incorporated in the same unit which screws into the thermostat housing. (I note that @airwave did mention finding two sensors on his 2.8idTD.) The engine temperature is normally controlled by the thermostat itself which is typically a wax capsulr device. These usually fail in an open position making the engine run cool.Gone from one extreme to the other....
Just had water pump done, and while it was being done and empty of fluid I gave them the rad switch and thermostat temp sensors to do.
That would appear to suggest a normal operating temperature, so why change the gauge temperature sensor? Fans do not usually operate in normal driving.Before it sat well below 90(straight up) constantly on the temp gauge and fans never kicked in.....
The new sensor may be reading high, but a high resistance connection coud give a similat effect. Nice to know that fans are working.....now it sits just below the red (overheating) on the temp gauge, so about 110ish, however I have heard one of the fans kick in at least when it's sat still and I give it a bit of a rev for a while.
Yes fans seem to be working, but gauge may be reading high. If OK before then possibly faulty sensor, but a high resistance connection to the sensor is apossibility. Also I have a niggling thought that some earlier Ducatos used a voltage regulator module for the fuel and temperature gauges, or was that only for the fuel gauge?So I think the rad switch has fixed the fan issue, but the new temp gauge sensors in the stat is still screwy, or the circuit has some issue somewhere.
I agree.I was panicking it was about to boil over on the way home, but it got to the high reading and sat there solid. Something is a miss.
I don't think the van is actually over heating, as now I know the fan switch is working, you'd be hearing them on constantly I assume if the temp reading was legit.
I don't think it was ok before, it was sitting really low. 90C is straight up on the guage which is where I'm used to every other car/van I've owned sitting under normal circumstances once warmed up, but it sat very much below that level. Initially i thought this was the issue with my fans never kicking in, but after a bit of back and forth on this thread i found out about the rad switch.The 2.8idTD only needs one temperature sensor for the gauge. A high temperature thermostatic switch for the warning light is incorporated in the same unit which screws into the thermostat housing. (I note that @airwave did mention finding two sensors on his 2.8idTD.) The engine temperature is normally controlled by the thermostat itself which is typically a wax capsulr device. These usually fail in an open position making the engine run cool.
I agree.
Access. On my 2.8jtd it is difficult to see the sensor unless yor remove air filter or intercooler hoses.Whats involved in changing the temp sensor again, now it's full of fluid? Will i lose a lot?
Can anyone recommend a decent make of temp sensor to go in the thermostat housing for these things?
Ahh ok, i can see the sensor fine, so i think it would be pretty straight forward to get out. Its more the logistics of the job i was thinking about. Like loss of coolant, or how to avoid that if possible. Obviously during this conversation I've found the sensor isnt linked to my fans, so its not that important, but it would be nice to get the right reading, something i can rely onAccess. On my 2.8jtd it is difficult to see the sensor unless yor remove air filter or intercooler hoses.
I was planning on filling the coolant reservoir to the brim, and replacing cap. I was hoping that fluid would pull apartial vacuum and only come out slowly provided that I dis a quick change. In the event I discoered that my gauge going immediately to normal ws due to a high resistance connection at the sensor. I gave it a squirt of contact cleaner and put everything back again without removing the sensor.
I usually use Ebay, where I can view a selection of makes/suppliers/prices.
I looked up my OG part number in eper, and searched based on that.Before you bought that did you contact the seller(autodoc by another name) with vin number to confirm part correct?
Hint parts listed by reg number are not guaranteed to be correct-essential to confirm with that seller via vin of vehicle.
NRF been great for rads and ac condenser for me
FACET good brand of old type temp sensor-provided the correct part
Or coastal motor homes via vin number- coastal are very good
