I wish they would go back to teaching how to use a roundabout the proper way reading the signs as approaching rather than this mad clock face rule that does not conform to common sense and the highway code.
Argreed just look at the roundabouts with lane making one could half lane one as left only 100m down the road lane one could be left and forwardDon't know what to do with that. Rather unspecific.
So what would be the 'proper' way? And will it work now that roundabouts are often more than a simple crossroads?
I can't see how the clock face is mad. Every direction sign is set so you approach from the bottom (6 o'clock). How does it not conform to common sense? Most roundabouts do not help much with lane selection. The highway code is a bit vague, necessarily so as roundabouts are so many shapes, with a wide variety of exit locations. The highway code gives advice on first exit, or turning right, but everything in between it says, "select the appropriate lane on approach to the roundabout". We have to get the new drivers to think.
We all await your thoughts on how to do this a better way, please.
but they are not reading the signs on the approach here the sign clearly shows 2nd exit to be at 12 o'clock so most of the day drivers driving for a living will use left lane for 2nd exit straight across, but 9 to 5 drivers and people who have moved into them flats will use the right lane as they moved the roundabout slightly so HGVs could get around it better so by eye 2nd exit looks past 12.Don't know what to do with that. Rather unspecific.
I tried to get my head round this earlier and even looked at the google maps and street view images to see if I could work out what the complaint was.but they are not reading the signs on the approach here the sign clearly shows 2nd exit to be at 12 o'clock so most of the day drivers driving for a living will use left lane for 2nd exit straight across, but 9 to 5 drivers and people who have moved into them flats will use the right lane as they moved the roundabout slightly so HGVs could get around it better so by eye 2nd exit looks past 12.
also 99% of drivers using exit 1 do not indicate so everyone assumes everyone that isn't indicating is turning left even if they are going straight on.
" local custom" what is that cant find it in the highway code.
if a roundabout has lane control different to highway code then it should be clearly signed as such, if it isnt then DVSA should campaign to get them up.
There are some fabulous roundabouts in Chesterfield...
Oh crap! I'm looking at a car for sale there. I think I'll get it delivered. :bang:
Haha it's not that bad.Where abouts is it in Chesterfield?
When would or wouldn’t you recommend a left signal to signal off a roundabout?
Best way to stop brakes seizing if car left for a long time or in cold weather? Advise I’ve found includes applying the handbrake just enough to secure the car, some people even advise leaving the handbrake off
