Skuur
Hello all,
Two months ago I've bought myself a 2007 1.2 Panda, 60000 km. Gave it its 60000 km checkup and replaced the oil filter, belts + water pump, etc.
One thing which I've noticed is that it has more difficulty shifting into 1st and 2nd gear, than it has shifting into 3rd and 4th gear.
(If my memory serves me right, 5th and reverse are also tougher to get into compared to 3rd and 4th.)
It takes more force to push the gear stick into those gears, comparable to when the clutch in another car isn't completely pushed down. Therefore my first suspect isn't the gear change cables connected to the gear stick, but the clutch?
It doesn't get better if I repeat the movement, for example, 10 times.
Now I do have Haynes' workshop manual, and I hoped for an easy nut-and-bolt adjustment, but it mentions the clutch is connected hydraulically.
Before I start taking things apart, I'd like to know if this issue sounds familiar to someone. Preferably with a solution.
