T14086 said:
No comparison,BM's cost 2 or 3 times price of most fiats,of course build quality will be better.
Of course you can compare them, they are bigger cars with bigger engines so the cost price will be more by ratio. But quality is not just cost, it is company approach, quality through design and quality of service. You can spend a lot of money on a car and still produce a poor one. Compare the small Japanese cars, similar price and spec and the same reputation for quality as BMW. The Fiat Panda is a good example, it has a good reputation.
T14086 said:
I'm honest with my customers,if I don't know the fault i'll say so! Honesty gains respect from the customer & when it is sorted they are thankful.Add this to the fact at my garage will al;ways phone customer to let them know the stage of repairs/diagnostic...I know cause I do it & often phone customer weeks later to check everything is ok.
You are one of the rare one's, I have never had a call from a Fiat dealer to see if everything was OK. To be fair they do call to say the car is ready.
T14086 said:
All Fiat techs are given a training plan,this always includes electrics/engine management & examiner operations which they have to do like it or not.If they dont come up to scratch they have to do it again!
The difference is you need to think outside of just this training and have a wider understanding of electrics etc. I'll give you a couple of examples I have had.
The heated drivers seat didn't work when I got the car. They said it was the switch, but using a multimeter found there was no 12V supply to the switch. They still insisted it was the switch and ordered a new one. After weeks of waiting they got the switch, which didn't work of course. They then said it would have to comer back for another day to connect up the Examiner. As it hadn't worked since new and the fact there was no voltage at the switch I suggested it was probably a loose connector. Anyway they said they couldn't do anything without the examiner connected. I decided to have a look at where the cables run and removed the cover of the plastic tray under the seat, in it were a plug and socket which weren't connected. I pushed them back in and the job was done.
The second was the gear selection indicator on the dash for the auto box. It kept flashing and not showing which gear was selected. Apart from that the gearbox was fine. The dealer said that according to Examiner it was stuck between two gears and ordered a new ECU. This arrived a few weeks later and when installed wouldn't let the car go over 40mph. They put the old one in again. I looked on
Eper and suggested the switch on top of the gear selector shaft used to show the shaft position wasn't adjusted right. They order a whole new set of selector cables and said they needed a special tool from Fiat to set it up. I noticed there were two spade connectors on the switch and thought they must be used for the set up. I took the cover off and it was obvious that when the gear selector was in a certain position you just adjusted the switch until you got continuity on the spade connectors. I did this myself and 10 minutes later it was fixed and has been ever since.
Anybody looking at the diagrams with a basic understanding should have identified these problems. Can you imagine how much this cost Fiat in parts and wasted time chaging the ECU etc. It also didn't require any special diagnostic tools.
Just to let you know the other experiences I have had.
The drivers seat base was replaced and when I went to collect the car, the trim on both sides of the seat was hanging off. It was obvious the plastic retaining clips had been broken off and this was something the mechanic would have known. There was no way they would have gone back on. Rather than say they would have to order bits, they just tried to get away with it. A total lack of any quality in the job. I showed the dealer before I left and they agreed to order new trim. I decided to fit these myself rather than loose the car for a few hours. When fitting them I noticed a relay on the seat was hanging down on the seat mechanism, this would have been crushed if I had moved the seat. Again just a lack of attention to detail.
The sunroofs have never worked properly from new, they loose the calibration so that they won't shut or open with "one" touch. I told the dealer I could reset them by holding the button in for 30 seconds, but it only lasted a few goes. On two occasions they just reset them and the second time they said they had spent ages testing it. The first time I tried the button it stopped working again. Fortunately I was at the dealers to show them. They said they would look into to it (again) and get back to me. They never have !!!!.
The day before the car was serviced last time the tyre pressure sensor alert came on to say the tyre pressure was low on one of the tyres. I checked the pressure using a digital gauge I had but thought that as I didn't have a pump and it was going into the dealer they could check it. I collected the car and the service sheet had a tick for checking tyre condition and pressure. As soon as I pulled out of the dealer the alert came up so I decided to go to the garage and pump them up, the valve covers hadn't even been removed there was brake dust all over them. The next day it went in to have the LPG fitted and I was allowed to have a look while they started the fitting. They removed a lot of components and hanging down was the pollen filter housing, one of the clips was still there and the other one had fallen off. It was obvious that the mechanic couldn't reach it properly so didn't bother to put it back right. I find this unbelievable and if you have ever done one you will know they don't fall off by themselves.
With regard to the recent recalls on the Ulysse for the airbag moisture problem and engine management software, how come it took Fiat several months longer to send out a recalls compared to Citroen and Peugeot for the same cars. During this time there was a accidental deployment of the airbags in a car in Europe causins injury.
To be honest given all these problems I have a severe lack of confidence in Fiat and their dealers, especially as they charge a premium for their services.
Please don't take this as having a go at you as you obvioulsy take a great deal of pride in your work and also have a lot of interest in what you do.
