Expasion tank is not part of radiator,yes is higher than radiator.Have you got an expansion tank higher than the radiator or a tank that is part of radiator on the side?
This is important
Thank you a lot for the answer.I will try it again. the first time, I hadn't opened the reservoir cap.Thank you.
Good then the coolant level is higher than bleed points.
When cold or warm(don't get burnt)
With the tank cap removed when bleed screws loose coolant should definitely come out.
That is completely normal. That is what coolant does, expands volume when it is getting hot. That's why there is an expansion tank and there is space above the Max line.One thing I noticed this morning was that the coolant level in the reservoir was between the 'min' and 'max' marks, exactly in the middle. Once the car warmed up, the coolant level rose to exactly the 'max' mark.
Very good!I let the car run until it reached operating temperature and then turned it off. I opened the small radiator bleeder screw two to three turns, and it started releasing a few air bubbles. I closed it and then opened the heater bleeder screw; unfortunately, nothing came out from there—neither bubbles nor coolant.
It needs to be warm engine and opened thermostat.Good then the coolant level is higher than bleed points.
Good morning.Yes second bleed valve is higher than expansion tankIt looks like bleed 2 is higher than coolant level.
Then you will need some pressure in expansion tank to over come gravity and get fluid out of 2nd bleed valve.Good morning.Yes second bleed valve is higher than expansion tank
Its a tiny bleeder screw on the other end of the radiator or on the end of a tube( i dont remember)That does sound like a thermostat problem. But you say it has 87°C stamped on its housing so that should be ok.
I would guess there is air inside the cooling system after that service and that is causing the problem. Cooling system bleed, may it be performed twice, if performed incorrectly does not get the air out of the system.
I recommend you do the bleed yourself, the right way.
Get the engine warmed, working temp then work carefully as it will be hot. Stop the engine and open the radiator breather screw. Take it off completely and with it off, top up coolant level until it comes out of the breather. Put breather screw back and do the same for heater matrix breather located on the piping. If at the end of doing that coolant level is higher than max line, do extract some out using a little hose or so.
It also can be done if you find an inclined space to park on while you do it, with car's front on the higher side.Then you will need some pressure in expansion tank to over come gravity and get fluid out of 2nd bleed valve.
The angle of camera makes mark and line look like they don't align but I suspect they do align when viewed correctly. Plus would not cause heat problem.Good morning and have a great week.
After visiting three different repair shops, unfortunately, the issue with my car has not been resolved. As I was thinking about the changes made at the first shop, I took a look at the car's timing. Could the problem with the temperature not dropping lie here?View attachment 489883View attachment 489884
That can't be the problem in this case.I haven't read the entire post.. but the only time I had a similar problem (running hot and the heater being required to cool the car) the problem was a faulty water pump.
The thermostat had 87 degrees Celsius stamped on its housing. Unfortunately, I did not test it the way you suggested. I replaced the radiator last year, along with the water pump.
Thank you for the answer.The radiator was changed last year.I had tried spray water at radiator,no result.Temperature stays high.The angle of camera makes mark and line look like they don't align but I suspect they do align when viewed correctly. Plus would not cause heat problem.
Did you have new radiator fitted ?
Have you tried water spray?
Thank you for the answerI haven't read the entire post.. but the only time I had a similar problem (running hot and the heater being required to cool the car) the problem was a faulty water pump.
Air in the system is a red herring.. all systems have air in them all the time... but they self purge when the engine is running, so worrying about every last molecule of air is a waste of time. A radiator is huge compared to the cooling requirements of the car, so a good system will work even with quite a bit of air in it.
Ralf S.
