Good morning to everyone!I put an obd reader on seicento.I drove the car and then let it idle.I can see on obd that the fan comes in at 97c and the temperature goes at 100c.The fan still working about 10 minutes and the temperature drop at 93c,then the fan cut out.Do you think that temperatures are right;What is your temperature readings;Thank you a lot!
Thanks a lot for your answer Ralf S.At 97c fan comes on but but the temperature goes up to 100c.These happen at heavy traffic.After few minutes goes down to 93c.Maybe plays role and the hot weather here for that.
I think (from memory again) that 102C is where the second fan/higher speed cuts in, if the car has it. Anyhow.. your sounds cool (do you see what I did there? )
Thank you Ralf S.for your reply.I believe that car doesn't has second speed or maybe i don't listen it,when the fan cuts in is very quiet and always the temperature is at 97c.In the obd i never see 102c,the higher temperature i have ever seen is 99-100c.Thank you a lot for you help.
