Technical  Combustion problem.
ccavalles
Good morning.
I am trying to solve the problem with my Seicento 1.1. The car had a faulty camshaft sensor wire. Sometimes it would stall and not run combustion properly. I have replaced the wire with a new one, but the car is still emitting smoke and soot. It starts on the first try, no problem with that. The injectors were cleaned. Curiously, it didn't pass the vehicle inspection this year because of emissions; I touched the wire and it passed without any problems. I removed the spark plugs and they were dirty with soot. I put them back clean, but it still emits black smoke. Any idea what it could be? I see all the wiring is fine, coils and wiring were also replaced with new ones not long ago. The catalytic converter is also relatively new, as are the sensors.
When running, sometimes it works correctly and other times it seems like it has no power. But it does not stall.
In the video, more black drops than usual can be seen. I have put some cleaner through the exhaust.
Model
fiat seicento SX 1.1
Year
2001
Mileage
136000
