General cooling fan - buying replacement
Pretty sure there's nowt else that's a straight fit.
I'm pretty sure the fan can be persuaded to come off, but.............
There are plenty of better quality aftermarket units out there at better prices than the OE units, but they'll all require some degree of fitting. Try Car Builder Solutions (Google will find) for example.
ive never achieved fan off blade due to corrosion issues
if money really is too tight to mention then ive fitted a fan from a siciento onto a punto by drilling out the rivets and then using bolts so anything is possible
just make sure fan pulls rather than pushes if you do do a monster fit
thanks for those sensible suggestions,
I'm considering fitting one of these, as it's the same money as a used punto one - and at least has a guarantee ..!!
http://www.ebay.co.uk/itm/300787978934?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
any likely electrical issues ?? ( not my Forte..!!),
I'll just splice into the old fan wiring loom to keep FIAT plug,
Thanks,
Charlie
hi
if you intend going this route your enemy is radiator core damage so i would pay a little more and get the full kit
Item number: 271057961611 ebay
