Technical Climate Control Fan Not Blowing
PedroMC
ML2
Hi, Newbie here.
We have a 1.2 Evo Punto with the digital climate control and now the fan blower has stopped working. I've initially thought it could be the blower resistor but I saw on another thread that the digital version has something different and I'm not sure what or where I'm meant to be looking to find the possibly faulty part. Another thread had mentioned this part, DENSO DRS99502 Blower motor resistor, but again, where is it and is this likely to be the problem.
Any help would be appreciated as its starting to get baltic up here in Scotland and my daughter uses the car for work.
I believe the digitally driven fan power circuits are part of that panel. Meanwhile until you get a replacement panel or it get it fixed, you can reorganise the fan motors wiring so it is isolated from the panel and gets a direct feed to run at full power when the ignition is on. But a word of caution the fan is using 9 amps continuously when the bearings (self lubricating bushes) are in good condition. As the cars age you need to oil those bushes or the fan slows down and takes more current and burns something out. The manually operated fan uses a 30 amp fuse. You will need to add a 30 amp inline fuse to your wiring
UPDATE. The new regulator resistor thing arrived on Friday from Autodoc and I wired it in yesterday, but now the fan blows all the time, and full when turned off. Could the new part be faulty or have they sent the wrong one. Don't know where the pollen filter is either and I bought a new one to replace it in case that was causing it to pull too much power.
